Transmissionfluid
Norway is a modern country with modern cars, and automatic transmissions are automatic transmissions no matter who builds them. I can't believe there isn't something he could get locally that would work.
Just so he's safe maybe he can add some Lucas to that green junk my truck driver friend always adds some Lucas to his transmission 9 speed big motha lol when he changes it so he might also check into that with the green stuff just a suggestion
$8 per quart sounds high, but I have no idea what things like this generally sell for in Norway. I understand that gasoline over there is around $10 or $11 (US dollars) per gallon. That's versus $3.50 to $4.00 over here, depending on location. On this basis, $8.00 for a quart of transmission fluid isn't too bad at all. It's about $5.00 a quart here for the basic stuff.
Also, it's not like you put transmission fluid in your car every week like you do gasoline. I'd just go out, buy enough of this stuff to fill the transmission, pour it in, drive the car, and not give it another thought.
punctuation
