Transmission problem
Old Aug 30, 2012 | 02:44 PM
69'442's Avatar
Took my 70 442 with dualgate for a drive to the beach. As I started on the way home I noticed the car would not shift into third gear. I slowed down to a crawl and then tried going again. This time it would not shift into second. I stopped and put it in park and then tried again. No second gear. The shifter was always on the left (her side). I slowly drove it home and started playing with the his side. I found the car would shift fine if I left it in third. It ran like it was in drive on the her side automatically shifting thru the gears. I got the car home. A few weeks ago I had a problem of it not shifting till it was warmed up. The filter was changed and fluid level good. I changed the modulator and it ran fine for the last 5 times I drove it. I don't think the dualgate was ever set up properly because whenever I tried it it would shift on its own. Could this be the cable adjustment, governor or the transmission? Maybe the dualgate needs to be rebuilt? Thanks for any advice.
Bob
67.f-85
May 7, 2010 04:22 AM
67.f-85
Apr 21, 2010 03:27 PM
thorpedo91
May 20, 2009 08:59 PM
veltboy618
Jul 9, 2008 08:20 AM
atownhockey19
Bravada
May 25, 2007 02:37 PM
