Transmission mount question
I've been looking for a new transmission mount for my 1972 Cutlass with a th350 transmission.
At the local auto parts store, they asked if I had the M38 or M40 automatic transmission.
Can anybody help with the correct answer?
Thanks in advance.
Thanks in advance.
Actually, I'm a little confused on this. I've never noticed a difference in trans mounts between a TH350 and TH400, but apparently the P/Ns are different. Anchor 2268 is the TH400 mount (on the left), 2378 is the TH350 mount (on the right). They sure look the same to me.
Also, Watch out for the parts store replacements. Most of them use metric bolts to mount to the crossmember. If you pick one up check them before going home so you can stop at the hardware store for the new bolts. The one I got from inline tube had standard threads. I took the one from the parts store back because i was not going to use metric bolts in a 40 year old car.
Dead Reckon
September 25th, 2014 09:33 AM
66ninetyeightls
September 4th, 2011 07:06 PM
