Transmission ID
Its mated to my 70 455. Is there any performance difference between different models years of TH 400's? Meaning is a later year (79 in this case) having a negative effect on performance when mated with the older 455?
Yes it is a TH400. Unless you find 'THM375" stamped on the tail housing which would have the 350 yoke spline count too.
The TH400 was GM's heavy duty offering compared to the standard duty TH350.
Performance differences? There are probably many differences in valve body, governor settings,shift points etc. I don't know those details.
My only concern would be the front and rear seal are good and pan/gasket doesn't leak. Otherwise, run it.
