trans making whining noise ?
Old Jun 9, 2009 | 03:07 AM
ls442's Avatar
I have a 67 442 with a 1971 455 and 350 trans with a stall speed converter it drives fine when i put it in gear drive or rev it makes a load whin give it more gas it go's away no noise in park or new fluid is clean + leavel is it the stall converter thanks ?
Old Jul 11, 2009 | 06:50 PM
csstrux's Avatar
Moved to appropriate forum.
Old Jul 11, 2009 | 07:18 PM
svnt442's Avatar
Torque conver took a dump. Happened to me last year with under 1000 miles on the trans. I'm STILL fighting with the shop that did the work to reimburse me. It happened before I moved and he said it was in the engine. I took him at his word even thought I knew better. I moved and had it replaced for $500. I'm gonna see him in a couple weeks. He doesn't know I'm coming. I'll get my money one way or another.
Check your fluid for metal shavings on the stick. It's probabaly the sprag or one of the impellers hitting.
Old Jul 12, 2009 | 01:29 PM
jimjr's Avatar
Possible cause of tranny whine...
My 67 Cutlass w/ 2speed Jetaway tranny and variable vane torque converter whines at low to part throttle (that is, when the kick-down switch works like it should!). The whine goes away as the kick-down switch shuts off at a higher throttle demand. I'm not saying that this is the problem, but I'm only offering it as a "shot in the dark". Keep us posted on the results and good luck! Jim
68Dreams
Apr 26, 2013 07:16 PM
Charles Ludwick
28
Mar 7, 2012 04:45 PM
Railguy
Dec 12, 2011 06:38 AM
hunter
Nov 18, 2011 11:45 AM
davisjd77
Alero
Jul 14, 2009 04:02 AM
