Torque converter issues....maybe????
Today I drove the cutlass to work and on the way back it started whining really loud. It would change frequency and it would get louder with rpm increase. Around 2700-2800 rpm it would make grinding noise which would turn into loud whining as the rpm increase. Could this be a torque converter? I have Hughes 2500 (stall 2800). When I let go of the gas it would quiet down. when I was pulling the car in the garage (I have a steep driveway), it made almost ringing noise when I have it some gas.
I already ruled out the power steering pump, alternator, water pump, belts, and everything else on the engine. It's definitely coming from under the car.
I checked the fluid and it seems like there is quite a bit of silver on rag when I wiped the dipstick. Transmission shifts fine and the fluid doesn't smell burnt.![Confused](https://classicoldsmobile.com/forums/images/smilies/confused.gif)
Thanks in advance.
Thanks in advance.
Direct drum sprag is a common failure BUT you loose second gear. You need to do a stress test. I recently had my th350 eat a sealing ring on the pump. Trans shifted fine and drive fine while crusing but when you got on it and hit second gear and the rpms shot up as was my case. I took it apart and everyone swore it was the sprag but i it was a 50 cent part lol. Seems to be working fine now . Give it stress test see what it does under heavly load like w.ot.
Thanks guys. I will talk to the guy that rebuilt it. Looks like it might be time for the th400 to go in.
Dang, I have to get under the car again. I just finished the coilovers and control arms and bunch maw's.
GINCSC
December 19th, 2015 01:49 PM
86odls
March 25th, 2014 06:08 AM
SPEEDROCKET
December 18th, 2007 06:35 PM
