TH400 GTO to Cutlass question
Old Feb 13, 2009 | 02:57 PM
sklbndt's Avatar
Anyone know the differences, if any, between a TH400 that would have been in a GTO versus one in a Cutlass? Am considering purchasing one for my Cutlass that came out of a GTO. Thanks in advance.
Old Feb 13, 2009 | 03:39 PM
gearheads78's Avatar
car guy
Both will be the same
Old Feb 13, 2009 | 05:40 PM
Ranzan's Avatar
Getting There
X2 except you will have to wash off the pontiac koodies!!!!!!!!!!!!!!!!!
Old Feb 13, 2009 | 07:41 PM
The GTO and Cutlass TH400 transmissions will physically interchange. There may be some differences in the shift points or other programming, but the two will interchange.
Old Feb 13, 2009 | 09:45 PM
sklbndt's Avatar
And what sort of problems, if any, might this present?
Old Feb 14, 2009 | 05:51 AM
For most stock or nearly stock engines, nothing at all. If you had a W-30, for example, the stall speed and shift points of a non-OW trans might be a problem.
Old Feb 14, 2009 | 06:08 AM
Bluevista's Avatar
Registered
Hey...I can sit in the back seat of my Vista Cruiser and look up at the trans in my goat.
Look the same to me.
Old Feb 14, 2009 | 06:19 AM
sklbndt's Avatar
I'm going to be going with a stock 69 Toro Engine (non w34). Can you, or anyone else, give me an idea of what coded TH400 I should be looking for? Looking in my chassis manual I'm thinking an OD, OG, or OW code would be good.
The GTO trans I was looking at was sold and since I don't need the trans right away (lots of work to do) I'm thinking I'll hold out for an Olds transmission.
TRW
Jan 21, 2011 05:38 AM
Danielle's 71
Apr 14, 2009 07:32 AM
jcs933
Drivetrain/Differentials
Dec 15, 2008 07:56 PM
Converted Goat Farmer
Dec 14, 2008 10:44 AM
