TH-400 shifts too late
Old Mar 30, 2012 | 02:36 PM
1976Oldswagon's Avatar
this, and I have a vacuum leak.
my friend in school who's family does transmissions told me there is a vacuum line running to the transmission, this would explain both problems...one problem though-I can't find it to save my life.
car is a '76 cutlass cruiser (455) and TH400.
where is this vacuum line?
Old Mar 30, 2012 | 02:50 PM
Qwik71442's Avatar
Full-time Taxpayer
modulator connects on the passenger side above pan rail by dipstick tube and goes to intake vacuum
Old Mar 30, 2012 | 02:56 PM
thanks man
Old Mar 31, 2012 | 06:10 AM
It needs to have manifold vacuum on it.
Old Mar 31, 2012 | 06:15 AM
If you can't find the line to the vacuum modulator, then perhaps it's not there...
Old Mar 31, 2012 | 10:10 AM
Rickman48's Avatar
If that's not it, could be a broken spring or stuck weight in the governor!
Old Mar 31, 2012 | 12:48 PM
67442HT's Avatar
Check all basics first, and that is a vacuum line connected from manifold vacuum to the vacuum modulator on the right side of trans and it is getting vacuum from the engine.
Old Mar 31, 2012 | 05:43 PM
I found a severe vacuum leak, but the symptoms are still there...the hose between the trans and the manifold is metal, and as far as I can tell intact.
I bottomed out REAL bad the other day, and there are fresh scratches on the trans where the vacuum line goes in.
how does it work, and how hard is it to replace/repair?
Old Mar 31, 2012 | 06:52 PM
Are there signs of ATF in the vacuum line / hose?
If so, replace the modulator.
If not, pull the line off the manifold and give a good suck on it (or get fancy and use one of those hand pumps with a gauge).
If the vacuum leaks down, and the lines are all good, replace the modulator.
Old Mar 31, 2012 | 06:57 PM
I won't be able to get it on a lift until tuesday, I will report back then, thanks for your help.
Old Mar 31, 2012 | 07:40 PM
No need for a lift - just pull the vacuum line and look and feel for ATF.
Similarly, no need for a lift to suck on the end of the line.
Old Mar 31, 2012 | 08:37 PM
Rickman48's Avatar
What's a lift??
In my 60's, and still doing transmissions on the ground!!
Spoiled kids?!?!
Old Apr 1, 2012 | 09:13 AM
Some modulators are adjustable, so if everything checks good and it still does it, stick a small flat head screw drive into the inlet on the modulator and back off 1-2 turns.
Old Apr 1, 2012 | 09:17 AM
TripDeuces's Avatar
Check the plastic connectors at all the junctions where vacuum lines are tied together. If there's a crack in one you can miss it easily. Ask me how I know
Old Apr 3, 2012 | 02:43 PM
the steel line runs all the way to the transmission, I can't easily check it. from under the hood there is no residue of ATF, and the transmission and line holds its vacuum. to double check it, I disconnected the line from the steel one, plugged it with a pencil, and started the engine. still a severe vacuum leak. so I replaced a mile and a half of vacuum line, and checked all the connectors I could, not including the ones under the carb. tomorrow I can get a blowtorch and use the blowtorch method to find the leak.
could a vacuum leak somewhere else in the system cause the trans to shift late? all lines directly related to the trans are connected.
Old Apr 3, 2012 | 02:50 PM
Rickman48's Avatar
The modulator has rubber connections at both ends of the steel line!
Check under the car, too!
Curious - how does this 'blowtorch' method work??
Old Apr 3, 2012 | 02:55 PM
Blowtorch???
Old Apr 3, 2012 | 03:01 PM
my line is metal till it enters the trans, and holds vacuum from under the hood.
the blowtorch method for diagnosing vacuum leaks-
get a blowtorch, propane works best. start the engine. turn the blowtorch on DO NOT LIGHT. run the gas over the vacuum system untill the engine races, when it does, the propane is entering the manifold and burning-thus telling you where the vacuum leak is.
courtesy of my auto shop instructor.
Old Apr 3, 2012 | 05:33 PM
FOUND IT!!! damn vacuum advance distributors...what is this modern sorcery?
the hose goes straight into the same set of vacuum lines as the one that goes to the transmission, explaining the shifting issue...the distributor had gotten so loose that I could turn it by hand, I don't even think there is a bolt on it anymore...thanks for the help fellas, I got it from here.
Old Apr 3, 2012 | 07:47 PM
Rickman48's Avatar
Never heard of that method - and if you've got a bad wire, bet it scares the hell outa ya!
Old Apr 4, 2012 | 06:36 AM
Same theory as starting fluid!
coppercutlass
Dec 31, 2012 11:22 AM
Pelican
Apr 1, 2012 08:52 AM
tiparosa
Feb 8, 2008 06:57 PM
Arctic Bravada
Feb 9, 2007 06:08 AM
paul in san diego
Jan 15, 2007 08:01 PM
