TH 400 & Jetaway
Old May 20, 2017 | 03:13 PM
67Rocket's Avatar
TH 400 & Jetaway
Do Jetaway and TH 400 trans. both have 32 spline output shafts? Thanks
Old May 20, 2017 | 04:11 PM
svnt442's Avatar
No. It's the same size as a TH350.
Old May 20, 2017 | 07:07 PM
To clarify, the Jetaway output shaft is the same as a TH350. The TH400 output shaft (and driveshaft yoke) is larger.
Old May 20, 2017 | 07:15 PM
svnt442's Avatar
Thanks Joe. I suppose I could have been a little clearer on that.
All I did was look up the output shaft seals for the transmissions to determine what size they were. The output shaft seal Jetaway and the TH350 is 1.502" ID, and the TH400 is 1.887" ID.
Old May 20, 2017 | 07:20 PM
Yes, techniques like that are how I usually find out if parts are the same or not. As for GM transmissions, every Oldsmobile RWD trans (auto and manual) use the same output shaft EXCEPT the TH400 and the M22 Rockcrusher.
<Gary>
Jul 11, 2014 05:24 PM
Sid
Sep 19, 2011 07:12 PM
kings65Cutlass
Jun 2, 2011 07:13 PM
CUT-N-UP
Mar 17, 2010 12:40 PM
clloyd
May 12, 2006 07:28 AM
