TH 200 4R TRANNY SWAP HELP!!!
I have an 82 Cutlass which required a motor swap. For reasons I'm too embarrased to display I had to replace my th 200 metric transmission also. I ran across a th 2004r transmission out of a Pontiac Parisienne so I slapped that into the ole Cutlass. I thought I was all good to go but I cant seem to find a column shifter linkage that would work. The 200th metric won't work, and the 2004r wont work. Please help!!!
Well,
Got under the car yesterday for two minutes and for some reason everything seemed to link up. I fixed the problem....I dont know what I did wrong before....but I'm glad everything works!!!
Now to try and fix my WOT problem.......
Well,
I know that that isnt the promblem. When I floor it...thats when it shifts right. When I try to drive it like a regular car it doenst know when to shifit between gears. I installed a new WOT linkage, but I'm pretty sure the internal components of the transmission are jacked. I unscrewed the WOT kit to see how the pin would move. I assume it is supposed to move in a up and downward motion...but it doesnt quite move like that. I can wiggle it all around the hole lika a joystick. But it doenst move up and down....so I never hear any audible clicks. Know anything about this??
I have no idea what a "WOT kit" is, but if you are talking about the throttle valve cable, it MUST be adjusted properly for the trans to shift correctly. Failure to do so will destroy the trans eventually.
JohnnyBs68S
26
September 7th, 2014 06:53 AM
BeenThere
September 26th, 2013 08:35 AM
ChefDeadpool
October 28th, 2011 04:18 PM
