T-5 swap
Old Dec 29, 2009 | 12:54 PM
1964f-85's Avatar
T-5 swap
Well getting ready to yank my Muncie close Ratio for a rebuilt Mustang T-5.
I am rebuilding it with the toughest gears, bearing supports and parts I can find to see if it will hold up (I hope).
Has anyone else put a T-5 behind a 455?
If so I would like to hear about the experience.
Old Dec 30, 2009 | 06:26 AM
Not for long!
Also, do you need to change the Ford input shaft to GM?
Old Jan 10, 2010 | 08:50 AM
1964f-85's Avatar
minor trimming on the input shaft along with a Mustang clutch disc.
Put one behing a built small block and it lived(s).
i used to drag race with a saginaw 4 speed and it lasted a few yeas before exploding it guts all over the driveway.
I am going to give it a try, it will only take an afternoon to swap back in the muncie if I toast it.
I will keep you posted
Old Apr 30, 2010 | 11:42 AM
1964f-85's Avatar
Up date, T-5 is in and working and all is well. 75miles an hour at 1900 RPM!
'69CutlassVert'
Aug 25, 2011 07:19 AM
<maxone>
Nov 28, 2008 11:57 PM
<jimmy>
Nov 18, 2007 02:09 PM
SUGRUE
Feb 16, 2007 08:08 PM
ferg87
Aug 3, 2004 08:33 AM
