switching from a turbo350 tranny to a 200r4?
Old August 4th, 2013 | 04:39 PM
jlo98regency80's Avatar
I have a 1980 oldsmobile regency 98 and it has the olds 350 with a turbo 350 3 speed, I would like to get the 200r4 tranny with the drive shaft and other components necessary from a 1984 oldsmobile regency 98. I am just wondering if you guys have any advice or pointers? Thank you.
Old August 5th, 2013 | 08:06 AM
Yeah. Type "200-4R" into the search function on this site. This has been covered many times here. One note on your 98, however. You will need a correct 200-4R crossmember from a mid-1980s version of the B-body with a 200-4R. The wagons are probably your best bet since they used the 307/200-4R combo until 1990.
Old August 5th, 2013 | 12:14 PM
So the 84 olds 98 wouldn't have the crossmember?
Old August 5th, 2013 | 05:37 PM
Any B/C body with a 200-4R does have the correct crossmember.
Old August 5th, 2013 | 05:49 PM
Oh alright well yeah its cause I was originally going to get the 84 but the 80 was way cheaper well long story short I found 84 in the local mega u pull it junk yard and the engine and trany are working just fine its complete.
Old January 30th, 2014 | 10:45 AM
TexasT's Avatar
Be sure to get the tv cable, and associated carb brackets for it. You need this to have the trans live.
Old January 30th, 2014 | 04:41 PM
jag1886's Avatar
Make certain you get a good HD rebuild on that 2004r or it will die shortly.
paul879
March 16th, 2011 07:13 PM
Del70
October 13th, 2010 07:44 AM
442scotty
September 16th, 2008 05:54 PM
geckonz08
August 7th, 2008 08:33 PM
nice72
April 7th, 2008 07:26 AM
