Stall converter?
Does it cut off when you stop at a light? If not, it is a stall converter. Seriously, though, all converters "stall" Stock ones at a very low RPM, around 1200-1500 and performance converters at a higher RPM. You can try and determine it by launching hard from an idle, see how high it revs before it hooks, but that is not very accurate. What kind of car? Any reason to think it is other than stock?
It's a 72 cutlass with the 350 rocket. The guy I bought it off of put an edelbrock performer rpm intake manifold on it along with a edelbrock 4 barrel carb. He also put in a new tranny, which makes me think he might have put in a higher stall converter. What do you think, maybe?
stlregal
Nov 17, 2010 04:54 PM
