st-300
st-300
Hello, I have a 66 st-300 trans . I want to know what the best tranny fluid is to use? It has 8000 miles on it , has not been used since 1970. Also does this tranny have the variable pitch converter in it? Its in a f-85, I have not found any for sale, so if it goes bad it looks like it could be hard to get a new one?
Newer Dextron should be backward compatible. Yes, your ST300 (AKA "Jetaway") has a switch pitch converter. You can confirm this if the trans has two wires going to it instead of one. The 64-67 Jetaways were switch pitch, the 68-69s were not.
