Speedo cable leak at trans
Hey guys,
I've been seeing a steady drip of fluid form the speedo connector housing since I got the car. I'm sure it's leaking. THis is what Napa gave me for a seal but it doesn't look correct.
[IMG]
[/IMG]
It looks to me like there is an o-ring up in there. Could that be the problem? Couldn't find anything in the CSM about a seal or o-ring.
[IMG]
[/IMG]
[IMG]
![](http://i1117.photobucket.com/albums/k598/Mac_48/20140530_145423.jpg)
[IMG]
![](http://i1117.photobucket.com/albums/k598/Mac_48/speedocableattranny.jpg)
Pull that retainer off and take out the whole speedo gear housing. I think it has O rings on it. The plastic gear can then be taken out and you can get a look from the other end as well.Im not sure of the NAPA seal but it may be correct for inside the housing. That is the end of the gear your seeing inside.
I'm assuming it's a 350?
http://www.transmissionpartsusa.com/...-00047338a.htm
Aha ... whacha got there is ... http://www.transmissionpartsusa.com/...-00047264a.htm Speedometer housing inner seal with garter spring
Thanks guys. Now how about the kickdown cable seal? That's leaking too. Is it the top-hat style seal or the flat o-ring/rubber washer? Anything tricky about getting that cable out of the trans? Yes Prof, it's a TH350. That's the seal I got from Napa for sure but the page says it's for a 2004R?
Looks like I'll be putting off the engine re-install for another week
But a good opportunity to get the trans in shape. I hated the thought of bolting my purty motor to that greasy trans.
![Frown](https://classicoldsmobile.com/forums/images/smilies/frown.gif)
Macadoo, last I remember of that kickdown cable seal, its just a simple O-ring. I remember it costing me a whopping five cents.
It takes only a few minutes to check out. It just that one fastner like pictured. Sometimes getting the linkage back in its hole is tricky. I seem to remember it being spring loaded.
Right, spring loaded...I think I did one a long time ago. I think you need like a helper with needlenose or Visegrip needle nose to hold it out while you detach it + change the seal. It's the trans tube that has either an oring or tophat type seal.
Now, what, $75 for the new cable. Anyone know a good place to look?
