slip yokes/tci auto streetfighter
Old Aug 27, 2017 | 12:59 AM
onofre442's Avatar
hello... swap the old tranny today with tci auto streetfighter #211300 and was going smooth until we hit a snag. slip yoke of the original driveshaft will not slide all the way into the output tail shaft of the new transmission. seems like its bottoming out at around 1 or 1 1/2 inches into the shaft. inspected slip yoke and output tail shaft of new transmission and I could not find any restrictions of why its bottoming out. any suggestions or answer would be greatly appreciated....
thank you,,,
Old Aug 27, 2017 | 05:59 AM
edzolz's Avatar
How much torque has your old engine/trans combo got? It is possible your slip joint has been slightly twisted beyond the length it was inserted in the original combo. Or, maybe it has grease/dirt buildup inside. Take an old small brush (toothbrush) with solvent and clean out the splines in the slip joint.
Old Aug 27, 2017 | 07:58 AM
onofre442's Avatar
no grease/dirt buildup inside. when its bottoming out, I hear a solid metal sound, nor slip yoke has been twisted.
Old Aug 29, 2017 | 11:50 PM
onofre442's Avatar
hi all, fyi...I called dennys driveshaft and explained to them my problem. denny had the answer right away... problem was there were a lot of burrs present at end of each spline of the output shaft. took out the output shaft housing and yes there were quite a few. I took out my triangular file, found me a nice position underneath the car and work on it until I was sure it was smooth and no burrs. slipped in like butter after.....thank guys...
L69
Apr 17, 2012 06:08 PM
L69
Dec 25, 2011 08:12 PM
coppercutlass
Dec 13, 2011 05:04 AM
65cutty
Sep 16, 2008 03:49 PM
J-(Chicago)
Mar 6, 2008 10:25 AM
