shifting
Old May 20, 2016 | 05:29 PM
cheesehead3's Avatar
shifting
Hi. Need some help on a shifting problem. I,m looking a 1984 Delta 88 with 69000 miles on it. The trans will only work/shift if you do it manually. Any thoughts as to a problem and fix? I can get the car for 1200.00. It is in very nice condition. Super clean in and out. Worth it?
Old May 21, 2016 | 09:20 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
That sounds like a modulator, our 81 Delta 88 did the same thing. Problem is the trans should a 2004r trans with no modulator. I would check the trans fluid and TV cable and take it for a good test drive.
Old May 21, 2016 | 09:29 PM
z11375ss's Avatar
Senior Moment Member
x2 on that. Sounds like a really easy fix.
Matt15
Dec 20, 2008 05:15 PM
maskinen
Aug 17, 2008 11:29 AM
GOLD72OLDS
Oct 31, 2007 05:34 PM
nohn
Jul 22, 2007 10:57 AM
<jdhideaway@aol.com>
Brakes/Hydraulic Systems
Mar 31, 2005 08:15 PM
