Shifter linkage
Old July 12th, 2018, 08:52 AM
67Rocket's Avatar
Shifter linkage
I read somewhere a while back that GM used Hurst shifters but used their own linkage rods, etc. in the A body cars. Has anyone else heard this? Thanks.
67Rocket is offline
Old July 12th, 2018, 08:56 AM
My442's Avatar
Correct.
The GM version of the Hurst shifters are different from the aftermarket.
Rods, clips, and bushings are different.
The GM Hurst shifters use a bayonet mount, and the aftermarket ones use bolts.
The GM Hurst shifters do not have a stop bolt.
The handles for GM shifters are make and model specific.
The only thing that is common is the Hurst name.
Pete Serio wrote a book on Hurst, and it is a wealth of knowledge on the shifters.
My442 is offline
Old July 12th, 2018, 09:39 AM
That's unfairly harsh. The similarities are more common than the differences. The basic shifter mechanism is the same for factory shifters and an aftermarket Competition Plus. The biggest difference is the stop bolts. The aftermarket shifters have the nuts welded to the outer housings for the bolts. You can swap these parts from an aftermarket to a factory shifter if you want stop bolts. The internals are the same.
The snap-in stick is only for ease of assembly line installation. The shifter (less handle) is bolted to the trans and dropped into the frame before the body. The body is dropped, and the handle is snapped into place later on the assembly line. There just wasn't time to send someone into the car to reach down and start then torque two bolts (and look for one after it gets dropped).
Naturally the sticks are application-unique. They are for the aftermarket shifters also. Add the fact that the sticks need to clear unique consoles, and obviously you need unique sticks. Back in the day, Hurst sold dozens of different aftermarket sticks for specific applications. Most of those have been dropped over the years as demand fell off.
The differences in the rods again is primarily to simplify installation and adjustment on the assembly line. Function is the same.
joe_padavano is offline
Old July 12th, 2018, 02:27 PM
My442's Avatar
Joe,
Please post the interchange chart between the factory Hurst and the aftermarket Hurst.
Then we can debate "harsh".
What are you, a snowflake????
My442 is offline
Old July 12th, 2018, 02:28 PM
Seriously dude?
Thanks for your insightful and informative post.
Old July 12th, 2018, 03:12 PM
My442's Avatar
Seriously dude?
Yes, and please don't call me "Dude".
Anytime I can help, I am glad to do it.....
My442 is offline
Old July 12th, 2018, 05:59 PM
MOTORHEAD
11971four4two's Avatar
MY YOU ARE A Piece of MY442shit
I was inclined to show a few pics
Now just unhappy with cretins
OH WELL
stop by and see me some time
11971four4two is offline
Old July 12th, 2018, 09:07 PM
MOTORHEAD
HEY ^& ROCKET
If I can not get you squared away
I may have to instigate something else
Old July 13th, 2018, 05:49 AM
67Rocket's Avatar
Thanks for the information, I am looking for a linkage rod from a 67 442 for 1st/2nd gear. Will also post in parts wanted.
67Rocket is offline
Old July 13th, 2018, 07:43 AM
The Hurst aftermarket rods will work but won't look exactly like OEM due to the different adjustment provision.
Old July 13th, 2018, 11:30 AM
My442's Avatar
OH WELL
Do you kiss your mother with that mouth?
Stay classy!
My442 is offline
67Rocket
July 13th, 2018 05:51 AM
David DeCan
18
June 5th, 2017 02:24 PM
archeryshooter
July 15th, 2016 09:50 AM
507OLDS
March 28th, 2012 06:09 AM
jcl
August 5th, 2010 06:51 PM
Quick Reply: Shifter linkage
