Shift shaft seal remover tool
Just had to replace a shift shaft seal on the side of a TH400. I found that they make a tool to remove it very easily. I was having fits getting the old one out and my transmission guy told me about this. With this tool it is a 5 minute job. Without this tool it can be a couple hours trying to pick it out and riks damaging the shaft. If you have never done one, the seal is to small to drill a hole in and use a screw like can be done on bigger seals. This tool is only $7 at NAPA.
https://www.napaonline.com/napa/en/p/BK_7769250/
tim72
Drivetrain/Differentials
April 3rd, 2009 09:00 AM
