Shift points for TH400
I can't find any normal shift speeds for the 400. I've looked in my repair manuals and cannot find what you need. The good thing about the 400 is you can adjust the modulator on the passenger side of the trans to shift at just about any point you want. This is an easy adjustment. When I first installed my trans, it was shifting through the gears pretty quick, even on WOT. I adjusted the modulator to shift later, which also produces a firmer shift.
yankees
September 17th, 2012 03:18 PM
dirtydynamic
December 27th, 2011 08:34 AM
