Seized drain/fill plug
Old May 25, 2015 | 07:08 AM
jtdb153's Avatar
I attempted to remove the only plug on m21 tranny to change fluid, but was unable to get the plug out it appears to be seized. Heat was applied to plug,extensions on wrench was tried with no success any tricks of the trade to remove the plug.
Thanks guys for the advice I really appreciate it.
Old May 26, 2015 | 02:56 AM
Yellowstatue's Avatar
Cut a slot through the middle of the plug and use a very sturdy square shanked screw driver and suitable wrench to turn screw driver. Might have to drill it out. Then use a brass hex headed plug instead of cast iron.
Old May 26, 2015 | 04:56 AM
RetroRanger's Avatar
72 Olds CS
If you don't need it out today spray it everyday w kroil or pb blaster and let it sit. Then in about a week really heat it good, try longer a longer breaker bar by jacking the car up for more room
Old May 26, 2015 | 09:18 AM
Octania's Avatar
Impact wrenches can do wonders
you don't specify but if it is a square head then I suggest an 8-point socket and Hugh Jass breaker arm or long arm ratchet if you do not have air tools or access room for air tools. 1/2" drive or bigger.
Oh and the heat should be applied to the female surrounding part, not the male plug, what with heat making things expand and all that.
Old May 26, 2015 | 12:30 PM
jtdb153's Avatar
It is the square head plug,thank you for the advice I will give that a try.
Freddy B
Aug 18, 2015 09:50 AM
Dan Wirth
Oct 18, 2009 07:27 PM
Olds64
Feb 17, 2009 01:20 PM
prawnman88
Apr 27, 2007 07:54 PM
ztim
Dec 22, 2006 10:20 PM
