noise from th350 trans ?
It's a 67 442 with a 1971 455ci and TH350 trans with a stall speed converter drives - shifts fine fluid is clean- level no noise in park- neutral put in reverse or drive makes load winey noise rev motor alittle it go's away no noise while driving checked vaccum mod and line are good could it be the stall converter ? thanks
You might want to check the converter to flex plate mounting bolts/nuts for proper torque.
