New Clutch
New Clutch
I'm pulling my 4SP tran from my 70 W30, because the counter shaft is leaking. While doing this, will check the clutch. If I need a new one,what are you guys using? Been looking at the Center Force clutches, but I see some that look OK, for less money. I just drive the car normal, and not much a year. So is the extra money for the Center Force worh it?
Timely question, Harv:
https://classicoldsmobile.com/forums...tml#post528713
I've used various Borg and Beck style clutches and between the fatigue in my left leg rowing the shifter up and down PCH when I was commuting from Torrance to El Segundo and ultimately breaking the clutch pedal from metal fatigue (
), I changed to a Centerforce in my 70 W-30. I'll never go back.
![EEK!](https://classicoldsmobile.com/forums/images/smilies/eek.gif)
SuperNovass
March 5th, 2012 09:19 AM
