Need new torque converter but what size...???
Old Dec 9, 2014 | 01:28 PM
aribera94's Avatar
I'm working on a 73 olds omega with a stock th350 transmission and 350 rocket. I do have an after marker RPM performance intake and cam with a holly carb. My problem is when slipping out of park to 1st I get this huge jolt and will usally stall unless I feed some gas just before the gear change. I'm almost possitive it's because the stock converter can't compinsate for the power. My father is saying I need a converter in the 2800-2900 range but multiple auto stores are saying a 2400-2600 will suffice. If I do get the higher range one will that be michanicaly okay for my car or should I stick with the 2400-2600. Please let me know what you think
Ps. If you know what range the stock converter is that'd be great to know too.
Andrew Ribera
Old Dec 10, 2014 | 05:37 PM
Most stock converters are around 1800 rpm.
If you get a GOOD quality converter it wont feel mushy at part throttle. I would go 2600-2800. Im pretty sure Coan doesnt charge extra for a custom converter.
Old Dec 10, 2014 | 07:27 PM
captjim's Avatar
Andrew Ribera
This does not sound like a torque converter issue to me. What cam do you have in it?
Old Dec 11, 2014 | 09:36 AM
455man's Avatar
I'm taking this to mean he has the RPM cam also.
@.050 224 int./234 exh. and 0.496 int./0.520 exh.
Old Dec 11, 2014 | 09:59 AM
brown7373's Avatar
What rpm is it turning when you put it in gear?
I wouldn't think about changing a torque convertor until and unless you are sure that is the problem. Reminds me of when my 69 GTO back in 1972 was having a hard time going more than 45 or 50 up hills on the PA Turnpike. I was "sure" it was a fuel pump, so I pulled into a service station and told the mechanic I needed a fuel pump. He installed one and I paid him, but it had no effect. I paid for an unneeded repair, and he was correct when he said I didn't ask for his diagnosis, I asked him to put on a fuel pump, which he did.
Old Dec 11, 2014 | 10:52 AM
70cutty's Avatar
Beer Connoisseur
X2. I had a bigger cam than that in my 350 with stock converter with no issues.
Old Dec 11, 2014 | 11:46 AM
CutlassDad's Avatar
New Converter......
X2 brown7373 on idle RPM, with a couple of questions.
What is the idle RPM when cold on the fast idle cam and when warmed up at curb idle?
Stevec
Apr 20, 2012 05:46 AM
L69
Apr 17, 2012 06:08 PM
L69
Dec 25, 2011 08:12 PM
455Gbody
Sep 11, 2009 11:47 AM
old-mans-mobile
Jul 10, 2007 09:19 AM
