Need help converting 2spd to 3spd shifter
Old May 27, 2011 | 06:15 PM
budgdawg's Avatar
Well, just got the 3spd shifter in i bought off of Ebay...or at least that was what it was advertised as. Turns out it is a 2spd shifter. I was wondering if anybody might have a 3spd shifter out laying around, would you be willing to unbolt the detent plate and trace it on paper and send it to me so i can convert the shifter over. Milling one won't be a problem, just need the pattern.
BTW, when i complained of the shifter being misrepresented as a 3spd, the ebay seller responded..."its definitely a 3spd. Oldsmobile didn't have a 2 spd Powerglide" No joke, dummy. They had a 2spd Jetaway.
Old May 28, 2011 | 06:53 PM
Are you talking about the 64-66 shifter or the 68-69 shifter? Shiftworks sells 3 speed detent plates for either, as well as the gear indicator plate.
Old May 28, 2011 | 07:04 PM
budgdawg's Avatar
The 68-69 shifter. I bought a console from a 3 spd, so i already have the shift indicator plate. I saw shiftworks page, but $150 seems like alot of money when all i need at this point is the detent plate. If i can't find one to trace, I may take my detent plate off and try to cut a blank from it. Maybe i can figure out where each point is supposed to be.
Old May 28, 2011 | 07:27 PM
2blu442's Avatar
I think I have one. I can trace it for you or if you pay postage both ways I can ship it for you to use as a pattern. Then send it back when your done. Send me your address in a PM and let me know which way you'd like to go.
John
Old May 30, 2011 | 06:55 PM
2blu442's Avatar
Once last check before I ship this. Here's a picture of the one off my 1969 with TH400. I just want to confirm yours looks different front this. John
Old May 31, 2011 | 11:20 AM
budgdawg's Avatar
yep, thats the one i need. Mine only has 1 notch after the neutral-drive notch.
Old Jun 24, 2011 | 07:54 PM
budgdawg's Avatar
The copy is on the bottom. THe original is hardened case steel and the copy is mild, but it won't be driven daily so i don't see a problem.
Oldsmaniac
Jan 8, 2012 05:47 PM
jimbo67
Jun 1, 2011 06:35 PM
budgdawg
May 25, 2011 06:56 AM
RAMBOW
Dec 9, 2009 12:26 PM
|-K|=K
Sep 29, 2009 10:55 AM
