muncie or T10
Old Nov 19, 2011 | 01:07 PM
1968ragtop's Avatar
muncie or T10
I'm considering swapping a 4 speed in my 68 cutlass ragtop and looking for opinions. The car has a mild 455 (400hp) and 3.08 rear end, I'm planning on changing the rear end with a 3.31 posi. I'm looking for a wide ratio 4 speed. Should I look for a M-20 or a ST-10?? What are the advantages? Thanks.
Old Nov 19, 2011 | 01:10 PM
oldzy's Avatar
There is also the AutoGear 4-spd option. ie. M22W, M22Z, M20
Old Nov 19, 2011 | 01:19 PM
1968ragtop's Avatar
I'm not farmiliar with the auto gear option? Can you give some details?
Old Nov 19, 2011 | 02:17 PM
oldzy's Avatar
Basically a clone of the original Muncie. All new parts though, new stronger case, stronger mid plate, new gears (Italian are the ones to get IIRC). M22W has similar gearing to the original Muncie M20. M22Z has like a 2.98 1st gear. Pic below.
Old Nov 19, 2011 | 02:54 PM
1968ragtop's Avatar
Thats a nice peice, I'd like to do this on a budget though so I'm probably stuck with a M-20 or a ST-10
Old Nov 19, 2011 | 03:57 PM
joesw31's Avatar
I would install the m-20, and with the m-20 you can use a nice original shifter. The m-20 may be a little cheaper.
Old Nov 19, 2011 | 04:02 PM
1968ragtop's Avatar
I've noticed an original 442 shifter and linkage on ebay can bring $500-$600 nice peice but not cheap.
Old Nov 19, 2011 | 04:03 PM
joesw31's Avatar
Use a replacement shifter from hurst
Old Nov 19, 2011 | 04:06 PM
joesw31's Avatar
One more, its best not to cut corners on a 4 speed conversion. Example, if your crank is not drilled for the pilot bearing, then, the motor would need to come out. Also, what year is your block? After 1974 or so, they stopped producing the block that has the mounting point for the clutch ball.
Old Nov 19, 2011 | 04:17 PM
1968ragtop's Avatar
thanks for the info. My crank was drilled for a 4 speed from the factory, I'll have to have a look at my block though for the mounting point. If its not there I'm guessing you could go with a hydraulic clutch?
Old Nov 19, 2011 | 04:40 PM
joesw31's Avatar
I remember seeing on here or ROP, a member made an adapter that bolted to the block and was able to put the ball stud on the adapter.
fast67vellen2o
Feb 21, 2013 04:06 PM
ihengineer76
Jul 1, 2012 01:24 PM
charlierogers
May 21, 2012 04:49 PM
63 F85 Cutlass
Mar 10, 2012 07:13 PM
cowboy76
Jul 5, 2006 09:03 AM
