maaaaan
maaaaan
So I just got my car back today. Rebuilt transmission. I drove it for about 20 minutes. Put ithe in park and back in drive. There is a clunk noise when I put it in drive. I checked the trans fluid. It's good. What could be the problem? Thanks, you guys are always helping me!
Have you crawled under neath yet to check the drive shaft and u bolts are good and tight. How about those converter bolts, tight also?
Can you duplicate this same sound on an incline facing both up and down?
If all that checks out you need to know how the trans was built. If the wave plate in the forward drum if will have harsh forward engagement.
I have a similar issue with an older th350 of mysterious back ground thats in my dads car. I found that if its put in reverse and drive many times like parallel parking it will bang hard but if you are driving back it up and then put it in park no problem. I did have a shop replace all internal seals so i dont know if they left out the wave plate when they are assembled it.
Year of car, make of car, model of trans...etc...Why was it rebuilt? What was replaced? Stock or higher stall converter? Stock rebuild or performance build with a shift improver kit installed?????...etc...
Yes you need to inspect the Ujoints and converter bolts before you put the key back into the ignition. If either are found lose go back to installer with the "red ***"!
I just got under and there is a transmission fluid leak. It's hard to explain the location of the leak but it's like right under all the belts. 1985 Delta 88
I assume you mean near the front of the engine? Could this be on the passenger side? Assuming this really is red trans fluid, it's likely a loose connection from the cooling lines to the radiator. The lower flare nut is an absolute pain to tighten on these cars, and if it leaks, fluid runs down the lower radiator hose and can drip who knows where under the front of the car.
