looking for an extension housing,roto-hydramatic 5,'63Cutlass
Old Mar 25, 2009 | 06:22 AM
old.n.bold's Avatar
please!i want to drive my '63Cutlass asap!i have torn into&was planning on
replacing the governor(car would not shift out of low&was reccommended by you all to check gov.).well after inspection i was advised by trans shop
& others,that rings on gov.have worn the housing.so i am in so desperate
NEED of a good one or junk trans that may have a good one.any help is
appreciated & will be put to good use.thanx,Don 330 652 7336 old.n.bold
Old Apr 1, 2009 | 01:56 AM
64starfire's Avatar
700R4?
I'm in the process of getting a 700r4 modified to fit the 394. His name is Dave Smith, his shop is in Exeter, CA. Phone number is 559-562-3500. Might be worth the overdrive. Cost might even end up being the same by the time all is said and done. Good luck.
442much
Oct 23, 2016 06:22 PM
dantana
Aug 17, 2012 07:00 PM
KathleenF
20
Jul 25, 2011 04:54 PM
Kaline
Oct 21, 2008 10:12 PM
