Lockup converter control options
I am going to be putting a 200r4 into my car. I was wondering if it is possible to use the pcm plus what ever sensors/switches that are used to just control the lock up converter? I will not be using a cc carb. I dont know if that system relies on any inputs from the carb, but I thought they use the brake light switch and a map sensor to determine when to lock up the converter. Has anyone tried this?
If this is not possible, what are the best options I have?
Sorry, its an 86 Cutlass Supreme. Also I wanted to add the car did not come with a 200r4, I was wondering about using the pcm from the Olds Delta 88 I pulled the trans from.
Quick and dirty, is to run a hot wire, through a toggle switch, to the A terminal on the trans. Power on = TC locked.
Or you can buy a TCI lockup kit.
Norm
the "a" terminal is the positive supply from the brake pedal tcc switch. it only supplies power when the brakes are off.
the "d" terminal is the ground supplied by the ecm. the ecm grounds this line to engage the lockup clutch via the tcc sloenoid.
the proper quick and dirty method would be to switch the "d" terminal to ground.
you don't want the quick and dirty method!
bill
I'm afraid you've both oversimplified this. Yes, the trans wants to see +12V on pin A and ground on pin D for the clutch to engage. If the car's trans connector is still in place, then the method I believe Bill was intending to describe would be to use the existing connector, which will already have fused power and a brake switch in series. The tan wire going to pin D needs to be cut and routed from the trans connector to a toggle to ground. Unfortunately your writeup wasn't clear about this.
To get back to the original question, the TCC function in the computer uses the VSS, TPS, trans gear switch, and coolant temp sensor inputs to operate the TCC solenoid. Using a non-computerized carb renders this function inoperative.
Has any one used the tci lock up kit? How exactly does it operate? Does it operate auomatically, or does it use a switch like mentioned above? If possible I would like it to operate close to stock.
http://www.tciauto.com/Products/Inst...76600_inst.htm
Should answer any question you might have.
Norm
Norm
Norm
Norm
It has been a year (or two?) since I did my 700R4. I remember wiring the Brake/TCC switch into the circuit, after the fact, to make it a bit more sophisticated.
Norm
Yes, at least on the 200-4R it is. The ECU switches the ground side of the solenoid; the brake pedal switch cuts the power side as a backup. I'm looking at my 86 CSM as I write this to be sure, since memory is the second thing to go and I can't remember the first...
