knowing what trans i have?
hello everyone im just a new car guy and new to olds im used to chevy this isnt my car im doing this as a learning project its my teachers that doesnt no anything about cars im doing this in my high school auto class..ok the car is a 72 cutless with a 350 and no kick down cable what kinda trans is it a th350 or th400.i would like to know cause i need to change filter and gasket
![Confused](https://classicoldsmobile.com/forums/images/smilies/confused.gif)
This car should have a Turbo 350, but I have learned to never say never.
If the pan is rectangular with one corner cut off, it is a T350. If the pan looks vaguely like the Rio Grande side of Texas on one side, it is a 400. 400s have electrical kickdown switches with no downshift cable.
hello everyone im just a new car guy and new to olds im used to chevy this isnt my car im doing this as a learning project its my teachers that doesnt no anything about cars im doing this in my high school auto class..ok the car is a 72 cutless with a 350 and no kick down cable what kinda trans is it a th350 or th400.i would like to know cause i need to change filter and gasket![Confused](https://classicoldsmobile.com/forums/images/smilies/confused.gif)
6 bolts secure the tail housing to the TH400
4 bolts used on the 350
You sure you don't have a kickdown cable, located next to the throttle cable, on the firewall, leading to the pedal lever inside the car?
That's common on 70-72 or so Cutlasses.
The 1969-72 A-body cars operated the cable directly off the accelerator pedal, not the carb. Look at the firewall and you'll see a second cable just below the accelerator cable.
Ok thank you i was looking in the wrong spot for the cable...this has been my first older car and my normal auto teacher is gone this is my subs car and im only 18 the most kinda work ive done like this has been on my 91 chevy truck thanks for the help
Back to your vacuum question, the 350/375/400/425 transmissions use a vacuum modulator to control shift points. You'll see it on passenger side of the transmission- it's a round thing with a vacuum hose hooked to it and then to a steel line that goes to the intake manifold. Engine vacuum varies with throttle opening, so the vacuum modulator is an efficient way to control shifts.
If the hose comes off or the modulator fails, the transmission will still shift, just way late as the governor is controlling shift points then.
Keep asking- we'll help.
Don't assume that because it was a 350 engine that it came with a 350 trans. I had a 72 Supreme that came with a TH400 behind a 350.
But if you found the cable on the pedal than you do have a TH350 for sure.
I see Joe is right as usual
Not even a W31 could be had with a TH400. But I see in '70 a small block Delta could be had with a TH400.
It seems as if it should've been an option all the way across the board
![Big Grin](https://classicoldsmobile.com/forums/images/smilies/biggrin.gif)
(And don't confuse the TH400-based TH375 with the TH350-based TH375B - clear as mud, right?)
