Kickdown and Switch Pitch Solenoid replacement in ST-300 Jetaway
I've got my 330 tuned and running well, now I'm working on my ST300 transmission.
I tested the two prongs on the driver's side of the tranny, the lower vertical (I assume kickdown) makes the clicking sound so I believe it's ok). The upper horizontal prong doesn't click, so I will need to replace the solenoid for the switch-pitch.
1.) I have done some research and found 1993623 as the part number for the replacement solenoid. Is this correct for the 1964 Jetaway w/ Switch Pitch?
2.) Are the 2 solenoids the same on both the kick down and switch pitch or do they have different part numbers?
3.) What is involved with replacing the solenoids? Can it be done w/out removing the trans from the car?
4.) I've come across the Bruce Roe switch pitch controller box, does anyone have experience with these?
I just want to make sure before I spend the money on parts....
Thanks!
Thanks!
I have a TH 400 Kickdown Switch Pitch and mounted on an Olds 67 and I have never managed to find these two parts but doing research I discovered that my transmission is very rare and much sought after by Collectors will find what you need and if I beg you to put photos to see if they are compatible to mine.
Thanks!
Thanks!
Hi Joe
is this.
http://www.fatsco.com/
I also hope to find the spare.
the rebuild kit I got had everything but the solenoid and switch-pitch.
is this.
Thanks Joe.
I haven't been able to locate a switch pitch switch 12V+ at idle and WOT. I figured the timed and vacuum ported switch from Bruce was the way to go. Are you familiar with the Bruce Roe box?
I also planned to run the Lokar TH400 style remote kickdown switch.
Not to mention... I'd rather not run switches up on the intake when I can mount both options remotely.
I'd rather not spend the $200+ on these two items before I get the solenoids working properly in the transmission.
I will call Fatsco for my trans pan gasket, filter, and solenoid(s).
Do you have any recommendations for a good trans fluid for my Jetaway?
67cutlass67GS
July 27th, 2012 06:19 AM
