Kick down problem...
My 66 with the 330/jetaway does not kickdown. I suspect that what I have seen elsewhere on this site referred to as the "kickdown switch" is faulty, but I am unsure as to how I can correctly diagnose this as the problem, and not something else.
I would just buy a new switch and swap it out to see, but it appears that these switches are not reproduced and can be somewhat expensive to get a working used/NOS one.
Could somebody give me some guidance as to how I can determine if it is the switch or something else that needs adjustment?
Thanks!!!
Thanks!!!
These two threads should help explain the switchpitch setup.
https://classicoldsmobile.com/forums...djustment.html
https://classicoldsmobile.com/forums...pitch-mod.html
