Jetaway to TH350 swap help
Old May 10th, 2013 | 05:18 AM
68oldscutlass's Avatar
Ok gang, little help. Even though my getaway is rebuilt And perfect, I think I'm craving an extra gear. I know the TH350 swaps no problem but what about kick down linkage? Right now mine runs by wire to a switch on my gas pedal that doesn't work anyways. Doesn't the th350 use linkage? Also any help with finding one decent price? Know of any for sale? Thanks!
Old May 10th, 2013 | 08:40 AM
Yes, the T350 uses a kickdown cable. There are a great many ways to aquire one, you can go rebuilt and have it delivered to your front door from Summit, Jeggs, or a multitude of performance trans builders. Or you can get a core and find a local builder, or purchase a known used 1 and throw it in. It has to be a BOP trans.
Old May 10th, 2013 | 12:25 PM
hookem horns's Avatar
Factory cable goes through the firewall and connects to the gas pedal, but yours will not have the hook. You can swap from a TH350 car. Can also run a generic kickdown cable to the carb, easy if you have an aftermarket carb.
Old May 11th, 2013 | 09:43 AM
I did exactly this swap on a 68 F-85 years ago. We used the kickdown cable and pedal from a TH350 car and cut the hole in the firewall. You can also get the cable and carb bracket from a mid-1970s car, but your carb may not have the provision for cable attachment.
Old May 15th, 2013 | 05:41 AM
WTony's Avatar
I have a th350 pedal if needed when you do your swap.
jerseyjoe
July 12th, 2019 11:08 PM
4Door67
November 29th, 2013 05:03 PM
billykissell
June 7th, 2011 06:17 AM
Flye
March 1st, 2011 06:50 PM
HouTXCutlass
September 9th, 2009 07:56 PM
Quick Reply: Jetaway to TH350 swap help
