ID year of my Muncie 4 sp transmission
DateCodes
The 1967 and 1968 vehicles received a year, month and day designator, Because the 3885010 casting was used in both 1966 and 1967, the case WITHOUT the year designator is the 1966 model.
DateCodes
The 1969-1974s received a year, month, day and ratio designator. Now you can tell what ratio the transmission had without looking inside. Its still a good habit to double check the gears to confirm the ratio because often times ratios were switched around.
Taken from 5speeds.com Muncie rebuild book.
DateCodes
DateCodes
DateCodes
DateCodes
fast67vellen2o
December 28th, 2010 11:32 AM
fast67vellen2o
September 27th, 2010 12:18 PM
