Hurst super shifter
Old Mar 19, 2022 | 05:49 PM
KCastl03's Avatar
Hurst super shifter
I have a 68 442 that was originally a factory manual transmission. I知 getting parts to swap back to a manual for it. One M20 trans I知 looking at comes with a hurst super shifter. Will this fit in the factory tunnel location without any modifications? Thanks!
Old Mar 19, 2022 | 06:01 PM
Oldsmaniac's Avatar
Originally Posted by KCastl03
I have a 68 442 that was originally a factory manual transmission. I’m getting parts to swap back to a manual for it. One M20 trans I’m looking at comes with a hurst super shifter. Will this fit in the factory tunnel location without any modifications? Thanks!
On my 67 I had to cut away some of the original hump, the rods are straight and the shifter has a short stick and sits higher.
Old Mar 19, 2022 | 06:13 PM
KCastl03's Avatar
Sounds good. I値l probably just sell it and get a competition plus for it instead. Thanks for the input!
Old Mar 20, 2022 | 05:40 AM
bccan's Avatar
Just confirming, at least on a ‘70 floor pan, Super Shifter does require some cutting.
Old Mar 20, 2022 | 06:17 AM
JIM'S w30's Avatar
I have one in my 69 442 fit good no cutting
Old Mar 20, 2022 | 07:19 AM
KCastl03's Avatar
any pictures? Thanks!
Old Mar 20, 2022 | 05:24 PM
JIM'S w30's Avatar
No pics but I also have the center console and it was center in the boot I also drilled the 442 shift handle to fit ,it's longer then the short hurst shifter handle but is still better then the stock shifter because of the shift rods being reinforced with the sleeves.
Dave Siltman
Aug 4, 2019 01:00 PM
friesjh
Jul 26, 2018 06:58 AM
RandyS
Oct 14, 2014 04:33 PM
sammy
Nov 5, 2013 07:02 PM
507OLDS
Mar 28, 2012 06:09 AM
