hurst shifter
Old Aug 30, 2017 | 06:38 PM
jwr7042's Avatar
hurst shifter
how does the handle come off without taken all levers off. Is there a way to do this? I have the 4 speed setting on my bench.
Old Aug 30, 2017 | 10:46 PM
jwr7042's Avatar
hurst shifter
How does the handle come off or does it? I have tried and cannot get it off. I just want to remove the handle
Old Aug 31, 2017 | 05:49 AM
Oldsmaniac's Avatar
If the stick is not bolted in you slide a thin piece of metal down along stick (thin knife blade) on each side and pull and wiggle the stick and it should come out. Sliding the metal down releases the tabs holding the stick into the shifter.
Old Aug 31, 2017 | 08:27 AM
VC455's Avatar
Barely Registered
Mine was rusted so badly that the blade alone didn't get the job done. There was slop in the shifter, so I sent it to Hurst for rebuild. They removed the stick in the process and I got back a pristine shifter.
Just an option if you have any further difficulty.
Old Aug 31, 2017 | 09:05 AM
Factory or aftermarket Hurst shifter? The stick attachment is different. And are you talking about removing the chrome stick from the shifter body? The shift rods have nothing to do with this.
Old Aug 31, 2017 | 09:11 AM
I merged your two identical threads. It is neither necessary nor in your best interest to post the same question in multiple forums. You'll get a better answer sooner if all responses are kept in the same thread.
Old Aug 31, 2017 | 07:36 PM
jwr7042's Avatar
I think is factory shifter and it is the chrome handle that I am trying to remove.
Old Aug 31, 2017 | 09:09 PM
If factory, slide a .010 feeler gauge down the side to release it. It can be a pain, and if corroded, you may have to put penetrative in there as well.
Old Sep 1, 2017 | 05:22 AM
To expand a little, the stick snaps in and is retained with a flat spring. The feeler gauge holds the spring out of the way so you can extract the stick. Sometimes you have to push down on the stick when inserting the feeler gauge so the spring doesn't get stuck on the stick.
67442nut
Sep 16, 2017 01:23 PM
JOHNNYOLDS442
Sep 27, 2015 06:23 PM
marxjunk
Jun 12, 2014 12:34 PM
69CutlassAlex
Feb 9, 2012 05:26 AM
olds4life
Feb 27, 2009 08:54 PM
