Hughes Converter
ARP washers. Use ARP washers to space the converter back just enough to clear the weight. You don’t want the converter binding into the pump either so check for clearance there as well. Done this in the past with no issues. FYI Hughes does make a BOP version with the threaded lugs.
Fletchmo72
July 6th, 2018 08:34 PM
