How to I.D. a 1956 olds hydromatic transmission
Old Apr 21, 2022 | 04:44 PM
Shot Gun Rich's Avatar
Also is the 1956 oldsmobile hydromatic transmission better than the 1954 & 1955 hydromatic ?
Old Apr 21, 2022 | 06:49 PM
Charlie Jones's Avatar
Phantom Phixer
There were two distinctly different transmissions used in '56 Oldsmobiles.
One was referred to as type "R" . Also known as a "single coupling" trans and it did not have a "Park" position
This trans was used primarily in standard 88 models, and is virtually identical to the 54 & 55 models.
The other was known as type "O" . Also known as a " dual coupling" or "Jetaway": trans. It had a "Park" position.
It was used primarily on Super 88 and 98 cars. It resembled the 57 thru 60 transmissions.
There should be a data plate on the side of the trans, If the number starts with R 56 it is a single coupling.
If the number starts with O 56 it is a dual coupling.
Old Apr 21, 2022 | 06:59 PM
Ok the I'd # is, 0 - 56 - 277992
that makes it a jet away ?
Old Apr 21, 2022 | 07:51 PM
Phantom Phixer
Yes.
Old Apr 21, 2022 | 07:53 PM
Thank you
Old Apr 21, 2022 | 09:46 PM
Also I read just a little bit, that the 56 hydromatic is better than the 54 & 55 hydromatic, is that true ?
Old Apr 22, 2022 | 07:53 AM
Phantom Phixer
It's all in how you define " better ".
The drag racing crowd preferred the quick, clean shifts of the single coupling " R " trans.
It was also lighter in weight.
Joe Average liked the silky smooth, but slow shifts of the " O " type trans.
Old Apr 22, 2022 | 12:40 PM
VC455's Avatar
Barely Registered
When I read the title of the thread, I heard Travolta singing, "Well, this car is automatic. It's systematic. It's hydromatic. Why, it's greased lightning!"
edshbennett
Nov 23, 2019 06:58 AM
James Burke
Jul 10, 2018 03:18 PM
congers
Dec 2, 2016 10:58 AM
cobalt
Nov 19, 2012 02:26 PM
starman63
Sep 16, 2012 08:43 AM
