four speed
four speed
i have got a 1970 442 455 automatic.i would like to change it over to a 4 speed .i found a 1975 trans am with a 400 4 speed .would the parts interchange.such as bell housing and pedals perhaps .also would a 75 trans am most likely have a saginaw? thanks alot
I heard that it wont, its only up to like 71. but im NOT sure. LOL i hope someone gets a chance to comment on this thread, because i can buy a saginaw from a chevelle for my 69 cutlass, and i was wondering if it would bolt up.
I doubt the pedals would work or linkage/z bar, as its a different body than the A body you have...the bell housing should work as BOP all had the same bolt pattern...I dont know what trans it would have but the trans should work...you will have driveshaft issues and yoke mismatch, shifter handle may be wrong angle, your 455 crank needs work or bushing for pilot bearing and may need to be drilled deeper. You will need a Olds flywheel.....the converson is do-able but not with most of the TA parts.
Wil Lopez
Ninety-Eight
Aug 29, 2010 09:41 AM
