Downshift cable linkage
This is just an informative note about said linkage. There was some discussion about this in another thread.
It appears that this linkage is accessible after dropping the pan. And there doesn't look to be any danger of the linkage falling into the trans when changing the cable. At least not on my '71 TH350.
A couple pics to illustrate:
Outside of trans...
[IMG]
[/IMG]
And inside....
[IMG]
[/IMG]
I hope this helps someone out
Outside of trans...
[IMG]
[/IMG]And inside....
[IMG]
[/IMG]I hope this helps someone out
Not sure I understand that Eric. Isn't the cable end small enough to go through the casting port without side to side motion? The attachment point on the downshift lever should be able to loosened and pivot sideways to allow the offset end to seat properly?
Nor sure what you mean Allan. The trans # is in the VIN?
The linkage rod is shaped like a jog in the road and that jog rests just above the hole in the trans. It seems to be a simple matter of sliding the cable tab down and across the jog. THAT part seems a little sketchy but it must be the tab's housing that keeps it from slipping off once installed. This is the setup for mine, anyway.
No, what I mean is on the DS of the trans there should be a stamping, (horizontal surface above the pan) and the last 6 digits of the original cars VIN should be included there.
Probably the same for my 72.
[QUOTE=Allan R;705328]No, what I mean is on the DS of the trans there should be a stamping, (horizontal surface above the pan) and the last 6 digits of the original cars VIN should be included there.
I don't mean to be dense but DS? I'll check it out tomorrow.
Yes, the dog leg on the wire slips into the cable end, but you have to give the cable slight twist to get it in. I don't know how but people have broken the little rod that comes out the trans. You know some people can screw up a ball bearing with a feather.
[QUOTE=Macadoo;705401]
DS is short for LHS... you need to brush up on your TLA's
j/k
Driver Side
Left Hand Side
Two [or Three] Letter Acronym
starting 1968 the engine and trans were required to be stamped with the VIN derivative. The four model and body style digits of the VIN were not used on the eng/trans, so
for a VIN of 344678M100123 = '68 442 convertible...
the trans and engine would be stamped "38M100123"
the model and body style "4467" are omitted.
So, if your trans stamp matches your VIN in the above manner, then that trans is original to the car.
j/k
Driver Side
Left Hand Side
Putting me down?! No dude, I didn't take it that way at all. I actually meant that I won't be able to talk real-world experience until I actually put the new cable on. With just a short piece with no sheathing, it was very easy to hook up. That may not be the case with a complete cable.
[QUOTE=Octania;705435]
j/k
Driver Side
Left Hand Side
Lol! And here I am scouring the trans section of the CSM looking for something that starts with D and S. The Downward Stroke mechanism, the Drain Sump, etc.
Thanks for the explanation. TTFN.
j/k
Driver Side
Left Hand Side
j/k
Driver Side
Left Hand Side
Looks like the original trans alright.
Trans = 31M176501
VIN = 342571M176501
I got the VIN from the Protect-O-Plate. I thought that was kind of cool
Thanks for the heads-up Allan.
j/k
Driver Side
Left Hand Side
Trans = 31M176501
VIN = 342571M176501
Be aware that the flange on the new cable (where the bolt goes through into the trans) is about 1/4" thicker than the original. I spent ten minutes trying to get it to thread in until I realized the bolt wasn't even going in to the hole. 3/4" 1/4-20 grade five did the trick.
I'm not quite sure what this black plastic tube is for. It's not pictured in the CSM and , although I won't know until I get the engine back in, it looks like it may keep the gas pedal from returning all the way. It slides on the cable easily and seems to be a spacer of some kind.
Also, I don't seem to have the clip. I'll post in the WTB forum but would anyone have an extra for sale?
[IMG]
[/IMG]
[IMG]
[/IMG]
84oldsDelta88
Jan 19, 2010 11:04 AM
