Dohh damaged torque convertor ?
I'm some sort of idiot I know, but yesterday I was removing the engine from my mates 72 350 Cutlass. We undid everything and started to lift the engine but it would only come out a inch or two then we lost all the fluid, I then remembered I'd forgotten to undo the 3 bolts hold the convertor onto the flexible plate. Is it possible that we have damaged the gearbox or transmission ? Should we at least change the main output shaft seal ???
If you actually got the engine to separate from the trans with the torque converter still attached to the flex plate, quite possibly. Ater you get the engine out, inspect the seal the seal, slide the torque converter back on the trans and give it a couple of turns to see if it spins freely.
Yea a seal remover will work. Careful not to gouge the aluminum housing prying out the old seal. I have a habit of putting a VERY THIN coating of RTV on the OD of the seal before sending it home. Be aware of the correct installation depth. Hand pack Vaseline (not bearing grease) in the rear of the seal to contain the lip spring...if it has one. Purchase a heavy duty (truck) seal. Take a good look at the pump for damage. Same for the converter wings and seal surface. Inspect the converter seal surface for a groove from the seal. If it has a deep groove time for a new converter. If its minor crokus cloth the seal surface if you marred it up. Coat the TC with trans fluid before inserting it into the trans. You do know how to seat a converter right?
Also inspect the flywheel for cracks at the crank and converter mounting areas.
Thanks for all the advice lads.
Dave
The converter has to "clunk in" in twice, keep rotating it and pushing backwards on it until jumps/clunks two separate times then it is fully seated. There cannot be any interference between the back of the engine block and the transmission bell housing when bolting them together. Once the bell and block are bolted together the converter must be pulled forward about 3/8" to contact the flexplate.
When putting the engine back in, if the converter pushes against the flexplate before the bell and block are flush together, stop. This means the converter is not seated and pulling it together with the bell housing bolts will damage the converter and/or the front pump.
Good luck!!!
Good luck!!!
All good advice here. How many miles on the converter & trans?
The pump is at the front of the trans. Its what the converter engages into as your "seating it". You should be able to see the input bushing(bearing) behind the seal w/o pump removal. If the converter snout and bushing it rides on look ok then you likely didnt damage anything. If you feel the need to inspect the pump do some homework before pulling it. Youtube it or go knock on the door of your local friendly trans shop for assistance. If you really dont see any damage on anything so far you may be ok? But IMO its all right there and accessible Ive learned thats the time to inspect verses doing it twice or damaging something.
