Cooler line routing
Old January 8th, 2012, 06:49 AM
therobski's Avatar
Cooler line routing
I decided to bend my own trans cooler lines for my 64 F-85 pro touring build. Most of the cooler lines should have the same bends getting around the oil filter and staying away from the exhaust. I need a picture or a diagram a least to give me an idea. I have the assembly manual for my 67 and it does not show the lines. It may have disappeared over the years. Thanks.
therobski is offline
Old January 9th, 2012, 06:09 AM
442Dave's Avatar
Cooler lines
I just did that last weekend and what I did was wing it. I was surprised but I got it done and it looks OK - I had an assemble manual and I changed from my jetaway from my 65 442 to a 2004r, so the lines were somewhat simular. I started from the radiator and worked back. When I got by the exaust and oil filter I just hand bent them carefully around it. Then I eye balled the connections and used my bender and got them correct. All on my back laying on the creeper. You can tell however I was not a professional but they work and really don't look that bad. Just take your time and be carefull.
442Dave is offline
Old January 9th, 2012, 08:03 AM
car guy
gearheads78's Avatar
Rob just bend some coat hanger to the routing that clears and looks the best. Copy you bends in the line.
gearheads78 is offline
Old January 9th, 2012, 02:14 PM
citcapp's Avatar
X2 that's always been my method and I use the hangers over and over again for other uses as well (hangers for painting small parts)
citcapp is offline
Old January 14th, 2012, 09:40 AM
therobski's Avatar
2nd question
Does the top trans line run to the drivers side on a 64-65 down flow radiator? This is for a 200R4, attached is the picture you can barley make out of the lines to the Jetaway.
Mike H.
December 12th, 2013 08:23 AM
getawaycar
September 30th, 2012 06:36 PM
#1CutlassSupreme
June 14th, 2009 08:45 AM
RAMBOW
June 9th, 2009 07:33 PM
Gary Lagacy
January 24th, 2009 06:35 AM
Quick Reply: Cooler line routing
