console shift hole
Old Apr 9, 2015 | 10:08 PM
Napoleon Solo's Avatar
I'm indecisive. Or am I..
console shift hole
Does anyone know exactly where and what size to cut the hole in my floor for the console shift for a '64 Cutlass?
Old Apr 10, 2015 | 05:50 PM
Octania's Avatar
I am going to go with "the floor"
anything else?
Old Apr 26, 2015 | 04:38 PM
Delmont 88 PA's Avatar
Hopefully someone can give you dimensions. If not, I had to mount the transmission (4 speed) on my Delmont 88 and kind of eye it up. So if you check from the bottom (from the shifter) and from the top (where the console hole is) and they are the same you are probably in good shape. Some of the other more experience Olds guys on the site might have a better answer but that is where I would start.
Old Apr 26, 2015 | 10:39 PM
Thanks for the direction. What I ended up doing was referencing the drawing from the '65 assembly manual. It still had no dimensions but it is fairly clear about position - if you line up the shifter on the floor as shown in the diagram. It only really fits one position so - there it is.
rgk1977442
Dec 8, 2021 06:51 AM
Alocatelli
Dec 10, 2012 07:49 AM
RAMBOW
Aug 18, 2012 12:00 PM
onofre442
Jun 25, 2012 09:56 AM
oldzy
Dec 10, 2010 02:38 PM
