chevy th400 trans same as olds th400
Old Nov 10, 2010 | 08:51 PM
ls442's Avatar
will a th400 from a older corvette work with a71 olds455 motor a have a th350 in it now the car is a 67 cutlass convt
Old Nov 10, 2010 | 09:12 PM
olds425's Avatar
You can make it work with an adapter, the bellhousing is a different pattern. It also may be a short tail shaft trans and I think the yoke is different between the TH350 and the TH400. Someone else probably knows more than I do and should chime in soon.
Old Nov 10, 2010 | 10:56 PM
Redog's Avatar
The 400 spline shaft is thicker than the 350 shaft, so you will need a different yoke is swapping between the 2 different trannies.
The 400 also came in 3 differnet tail housings. 4 inch, 9 inch and 12 or 13 inch (don't remember exactly) Also the speedo gears are inside the tranny housing, not the tail housing like the 350.
Yes adapter plates work well, but it sucks for us Olds guys. A BOP tranny to a Chevy plate is around $50, but a Chevy tranny to a BOP engine is closer to $100
Old Nov 11, 2010 | 04:33 AM
Rickman48's Avatar
I've used the BOP to Chevy plate behind a BB without incident.
Seems silly to have 2 prices as the difference is a couple of tapped holes!
Old Nov 11, 2010 | 05:59 AM
J-(Chicago)'s Avatar
Seasoned beater pilot.
http://www.afabmetalworks.net/Fabricated%20Parts.html
Old Nov 11, 2010 | 10:45 PM
Redog's Avatar
I agree
nj_cutlass72
Jan 2, 2013 09:19 AM
hoppers69
Apr 30, 2012 06:55 PM
charlierogers
Mar 10, 2012 06:31 AM
jeffreyalman
Jun 6, 2009 06:28 PM
Super88inWilm
Mar 30, 2006 04:32 AM
