Bad Tranny or what/ TH350?
I have a 72 cutlass with the 350 and hydramatic 350 tranny column shift, and my problem is that I can feel it go into gear (you know, a little jerk foward or back) but then when I hit the accelerator nothing happens. but it will idle forward and reverse. It's so weird, anyway, thanks for your help.
Sam
Sam
Yeah, you're correct there. I should check it warm, so i guess I'll do that tomorrow, I actually hope it is just me being an idiot, a quart or two of tranny fluid is cheaper than a new torque converter.
See, It's all about checking your fluids. Good for you. Let us know how it turns outs.
Yeah, and in a related note, when I got the engine hot enough to check the tranny fluid, I noticed that the fan wasn't moving...and then sure enough the rad cap let loose. After I shut the engine off I found out that the fan is hitting the fan shroud and was stuck. So, I'll fix that tomorrow and hopefully my fan clutch isn't ruined. Oh well, just one thing after another.
Alright, I got the fan shroud off and the fan is still working somehow. I then put 2 quarts or so of tranny fluid in and wow, it seems like the problem is 100% fixed. I need to fix the brakes, then I'll know if the tranny is in good working order or not. Thanks.
