Aluminum Trans Pan
Old Sep 28, 2021 | 07:18 PM
Phoenix8990's Avatar
Aluminum Trans Pan
I have a TH400 trans and am planning on a fluid change and see the finned aluminum covers and wondered if anyone can confirm if it really makes a difference in fluid temp? Is a trans cooler more efficient? Can you mix synthetic fluid with whatever happens to be in there now or is there is recommendation?
thanks
Steve
Old Sep 28, 2021 | 07:31 PM
gs72's Avatar
72Cutlass S
Do you race the car or have stall convertor. If not you are fine with the stock pan.
Rallye469's Avatar
I cannot positively confirm an A to B comparison with and without both a finned pan and/or cooler…
But I can say that with a deep TCI finned aluminum pan AND a trans cooler, it’s very hard to get my temps above 150.
I never liked the idea of my trans fluid sitting next to 200 degree coolant in the radiator.
-peter
Old Sep 29, 2021 | 02:45 AM
I seriously doubt you will see any difference in temp with an aluminum pan over stamped steel. About the only advantage of cast aluminum is most have a drain plug and are usually drilled abs tapped for a temp sending unit. With the thick pan rail flange, unless there is porosity in the casting they don’t leak.
The disadvantages:if your car sits low to the ground snd you hit something, cast aluminum pans don’t dent, they crack. They are also heavier, and more expensive. I can get factory deep pans and the required hardware from a used transmission warehouse for around 40-50 bucks, cheapest cast pan is around 125.
Old Sep 29, 2021 | 05:35 AM
VC455's Avatar
Barely Registered
If both the synthetic and conventional fluid are rated for your T-400, then you can mix in any proportion.
Oldssupreme
Jun 28, 2020 06:29 AM
1yesfan
Apr 1, 2015 10:15 AM
junior supercar
Nov 3, 2014 02:05 AM
coppercutlass
Jun 30, 2013 11:42 AM
1968ragtop
Jul 9, 2011 06:42 AM
