85 Olds Delta 88 Tranny crapped out
Old February 17th, 2015, 08:23 AM
DeltaDevil88's Avatar
Wont go in reverse at all and barely will kick into gear to drive from a full stop.
I replaced the filter,fluid and o-ring about 1.5-2.0 years ago
How much should a rebuild cost??? any suggestions in Dallas TX shops????
DeltaDevil88 is offline
Old February 17th, 2015, 08:53 AM
Professur's Avatar
Wow ... we are just blowing through transmissions this month. I suspect your car may be hiding a 200c under there. The standard (dealership) method of rebuilding one of those is to replace the case with one from a 350C .... and then fill it with the appropriate parts.
Professur is offline
Old February 17th, 2015, 11:10 AM
Its a Turbo Hydramatic 200-4R any idea how much a rebuild would run???
Old February 17th, 2015, 11:37 AM
Professur's Avatar
From the discussion in the two other transmission death threads, about $900. Plan to replace the torque convertor too. Keeping one after a transmission death is like taking a bath after your kids without washing the ring off the tub.
Old February 20th, 2015, 11:50 AM
TexasT's Avatar
What does the fluid look like? Does is smell burned? Is it topped off?
Might be a stripped stator support(second set of gear/teeth toward the trans/pump. These are/should be replaced with a hardened piece when the trans is over hauled.
Bottom left is the input shaft, front n center is the stator support. The pump will have to come out to press the new support in. I would get a pair of hard rings, larger boost valves and a spring to get the pressures up. Just cheap insurance to help it last longer.
Won't know what you have until you pull it and inspect. But if the fluid is full, red and smells like trans fluid, this is what I would guess.
Let me know if you need more info.
TexasT is offline
Old February 22nd, 2015, 05:50 PM
Car got towed today in this nasty cold rainy weather to a local transmission shop.
Old February 23rd, 2015, 11:31 AM
Professur's Avatar
Even the bravest DIYer has to take a back seat when Mother Nature gets her tampon in too tight. Did you get a quote yet?
Old March 2nd, 2015, 05:16 AM
Fixed and back up and RUNNING!!!! wasn't cheap.....
Old March 2nd, 2015, 07:22 AM
Professur's Avatar
details?
Old March 2nd, 2015, 11:26 AM
Originally Posted by Professur
details?
Rebuilt the transmission
Old March 4th, 2015, 06:33 PM
TexasT's Avatar
Who built it?
TexasT is offline
Old March 6th, 2015, 07:31 AM
Originally Posted by TexasT
Who built it?
The Transmission Shop Plano TX off 75
Old March 6th, 2015, 08:11 AM
morgan
pogo69's Avatar
probably close to 2500 these days
pogo69 is offline
Old March 6th, 2015, 10:14 AM
Not that bad but it was the most I have ever paid for a transmission rebuild.
$1500 comes with a 3 year warranty.
84oldsDelta88
20
January 12th, 2016 01:36 PM
Jannebill
March 1st, 2015 05:52 PM
Daniel2008
July 22nd, 2009 05:32 PM
ijasond
August 5th, 2008 07:05 AM
scrappie
April 9th, 2008 05:17 PM
Quick Reply: 85 Olds Delta 88 Tranny crapped out
