83 h/o
83 h/o
As my previous posts have stated My H/O has had all the computer equipment removed. Is there any way to wire up the lock up convertor on a toggle switch to make sure everything is working befire I spend any money on a kit to wire it properly. Also when ordering a kit what is the best one to get. Ron Francis, Painless wiring, etc. Thanks Larry
I went ahead and ordered TCI kit 376600. It looked to be a mostly complete kit that was priced about half way between the cheap and most expensive. Hopefully it will do what I'm needing it to do. Has anyone had any experience with doing one of these. Larry
sorry, just saw this. The Bowler kit is the best one out there, especially if you use it with an added vacuum switch. More info here: http://realoldspower.prophpbb.com/topic1840.html
