80s deltaa trans swap.
Old Apr 12, 2009 | 05:36 PM
easytobedead's Avatar
Just A BaBy {:
would a over drive trans fin in the place of a non over drive trans? there both 2 door delta 88s?
Old Apr 12, 2009 | 06:42 PM
It depends. The 200-4R WAS factory available in the 1980s B-body cars. The crossmemer is likely different. The G-body cars of that era got a modification to the frame when the 200-4R was released to accommodate the different crossmember location. I don't know if the B-body cars got this mod or not. There is an aftermarket bracket for the G-body cars if the frame does not have this mod. I don't know if this same bracket would also work for the B-body cars.
Old Apr 12, 2009 | 07:36 PM
Just A BaBy {:
ok cuz i have a 2 door 84 olds 88 that has an over drive an the car i am getting is a 84 2 door 88 with a non over drive. same year an all i should have all the parts there to just swap them?
Old Apr 13, 2009 | 07:45 AM
Yup. This is a total bolt-in.
Old Apr 13, 2009 | 07:46 AM
Actually, the one thing that will be different is the shift quadrant in the steering column and the gear indicator on the dash. If you use the three speed column, you will not be able to manually select first gear. Maybe that doesn't matter to you. The other column will bolt in.
Old Apr 13, 2009 | 11:49 AM
Just A BaBy {:
yea i know of this. i will be swapping every thing over to make it look like it came with over drive. now i just got to wait for some nice days to roll in {:
72olds442
Wheels and Tires
Apr 28, 2012 12:59 PM
rocketraider
Dec 1, 2011 03:51 AM
64Super88
May 15, 2010 07:24 AM
easytobedead
Aug 27, 2008 10:25 AM
falconsfan
Mar 18, 2007 08:33 AM
