72" Cutlass TH350 to 200R4
well, was going to rebuild the TH350 for my project, but scored a supposed low-mileage 200R4 for $200 today, so plans have changed a bit. i have seen a few write-ups on this swap, but had a few specific questions. first is:
-will i be able to get this to work with my 2bbl carb on factory manifold, or do i need to start keeping an eye open for a different setup?
-i have heard of the 200R4 having trouble holding the TQ on a BOP motor, can anyone that is currently running one comment? and are there a few upgrades that should be added before install? the motor is a 350 Rocket, and will have a RV cam, hearers and 2 a/4 dual exhaust, and depending upon the requirement possibly a 4-bbl and intake
- what all will i need to do, IE TV cable, and i understand i will need a lock-up converter and a solenoid? the car is a S model with a column shifter
- what would a good stall-speed be?
one main reason i was looking at a OD transmission is that this will be a drivers car, and i love driving high-way. this will be a dialy-driver, or switched between often for daily status.
What rear gear ratio do you currently have? If it's the typical 2.56:1 then it's already a highway cruiser with ~2000 RPM @ 60 MPH, depending upon rear tire height.
FYI, I drove mine daily since 1990 with 3.23 rear gears and short (25.6" tall) 245-60-14 tires with the engine turning ~2600 RPM @ 60 MPH.
thanks for the advice. i know that it will not last long is stock form, that is why i was looking for the parts list that would be needed for an upgrade. im not looking to replace every single hard part, as i know there are a certain few that seem to be culprit. and i hate to do it, but if i have to i can swap to a edelbrock intake and carb setup to get this to work properly, though im going to try andget it working on the 2bbl for now. so as for lock-up, i would like to do it. i just need to find the proper way to wire it in to actuate it. i'd like it to be an automatic operation, and not a manual as i have seen some guys wire up. and what would a stock stall be on this transmission, 18-2200?
X10 what Joe said. Do a search here. This has been discussed nearly as many times as the C.S. engine off-set myth.
Several vendors cater to the TH2004R HiPo crowd. Some at the 750-1000HP range! 10 years ago I would have said no way to this swap. But the aftermarket has stepped up to the call. Coan, TCI, California Performance Trans(Art Carr), Hughes etc...
Stock stall is dependent on the application and which converter is there.
Art Carr sells a 200 thats rated up to 400hp for $1600 with a warranty
There were th200-4r's that came from the factory ready for power. There are also many more that weren't. Use this page http://web.archive.org/web/200701281.../thm2004r.html to decode your tag to know what you've got. Without knowing what you've got, it's impossible to say what you need.
the top of the case is marked 409 G
the yellow tag is marked
CR F
085-872cr 1498
seems that it is out of a 85-88 LG4 305 powered Monte Carlo/Pontiac Grand Prix
You may have the experience and expertise to upgrade the 200r4 to handle more power. Just be aware that it is more to it than bolting in new parts. Port holes are redrilled and some custom fab work. I bought mine from Lonnie at Extreame Automatics. Here is his link and it shows what parts he installs for each level of performance. http://www.extremeautomatics.com/th2004R.php. It also has some very good info regarding TV Cable adjustment. Lonnie offers good advice. I followed his directions to a T and the transmission performed flawlessly right out of the box. Good luck with yours. There is a lot of info on the web for this swap. Most of them reflect a lot of frustration.
While that's a whole lot better place to start than the pitiful OG, you do have to remember that the Monte Carlo was still a sub-200 hp car ... and that bowtie block was a long way behind the Olds torque numbers. Given what you've got ... this will probably be a good page to start chewing on http://www.superchevy.com/how-to/tra...mission-build/.
Any thoughts of the 200r4 trans from these guys?
http://www.ebay.com/itm/2004R-Stage-...-/181659908761
http://www.ebay.com/itm/181662410016
I would also include a larger rev boost valve and boost spring to get the pressures up. I'm not sure what they do to the planetaries for better lubrication but I would reccomend a bearing to replace the bushing in the o/d planet.
I don't like the superior servo as it leaves out one of the cushion springs and you end up with a clunk on the 3-2 down shift. The ck or sonnax are better even though they cost more, imo.
Lots of opinions on 2004r. These are a few of mine.
You have two options. First, if you can find one of the ultra-rare and no-longer-in-production four speed dual gate shifters that Hurst sold (aftermarket only), you can adapt it to the factory console. These items are very hard to find and sell for stupid money when one does come up for sale.
The other option is the Shiftworks conversion kit. A member of our club has one in his 72. I am not impressed. Fourth gear (the OD position) ends up where Neutral used to be, and Neutral, Reverse, and Park are all crammed in the remaining space. I didn't care for it.
Thanks Joe you are a wealth of knowledge.
I really think you should change your user name to Joe bi-Wan Kenobi the Jedi Olds Master.
I just changed my rear gear from a 2.56 to a 3.42 and the tach used to be 2k at 60 mph now it's about 3900. I thought it would be around 2400. So I was thinking of switching to a 200r4 from my th350 and I already have a factory dual gate.
I've only driven it once since I got it back. I need to check and make sure it's shifting into 3rd gear.
Any opinions??
Any opinions??
Any opinions??
Any opinions??
I did this in my car 72 Cutlass with a 455. Would not do it again. It cost to much. By the time you rebuild the trans, purchase a new drive shaft, purchased the shiftworks conversion kit, bracket to attach ITV cable to the carb, and lock up controller, your $200 will be a minor part of the upgrade.
Do you have a total that you spent?
[QUOTE] The other option is the Shiftworks conversion kit. A member of our club has one in his 72. I am not impressed. Fourth gear (the OD position) ends up where Neutral used to be, and Neutral, Reverse, and Park are all crammed in the remaining space. I didn't care for it.[/QUOTE
Joe could you elaborate on what you did not like about the shift works kit. That up grade is next on my to do list. Right now I am using the original 3 speed Dual Gate. Everything is where it is supposed to be, but you cannot get to 1rst gear. IE: 1st gear on the shifter is really 2nd, 2nd is 3rd and 3rd is OD. I planned to change over to the shift works deal but it may not be worth the change.
I'm holding out for a real Hurst four speed dual gate.
Did this swap last summer and used BTO's TV-EZ kit (with modification) to work w/ my 2GC carb.
https://classicoldsmobile.com/forums...-look-out.html
I'm running a 3.90 rear gear and now w/ the OD + lockup, the RPMs are lower than w/ my Jetaway / 2.78 original gear. Used a Kugel KK02 linkage to work w/ my column shifter, it has an adjustable ratio so you can fine-tune the pointer / shifter detents to the transmission detents. P/R/N/D all line up OK, 3/2/1 land at various points around the "L" on the indicator, so you kinda have to count the clicks to know what gear you are in. Since I rarely use anything but D, not a big issue for me.
MDchanic
Wheels and Tires
22
August 4th, 2011 10:23 AM
81 regency
April 21st, 2011 06:18 PM
